Configures the import policy for BGP.
| policy-name | Specifies the policy. |
| none | Specifies no policy. |
N/A.
Use the none keyword to remove a BGP import policy.
An import policy is used to modify route attributes while adding BGP routes to the IP route table.
The following command configures a policy imprt_plcy for BGP:
configure bgp import-policy imprt_plcy
The following command unconfigures the import policy for BGP:
configure bgp import-policy none
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
